RA3WDK `s Homepage
COMPARING DIFFERENT LNA of 144 MHz Band For Use in Noisy City
A low noise amplifier is important to the "WeakSignal" receiver for MS , far Tropo , EME !
      Low noise figure and High IP3 is easy to achieve with modern devices, but the large number of extremely high signal levels
  from BroadCast FM and TV stations - bigger and bigger problems nowadays !
  I was not quite satisfied with the IP3 of my old LNA, when running his in my noise QTH.
The "Old-School" LNA with Cavity
( use MGF1302, 1602, 1801, similar)
Not simple constructions, need tune, low noise, harrow band , big size...
LNA 144 MHz / MGF1302 / 10mA / NF < 0,5 db
The LNA with SPF-5122Z GaAs pHEMT MMIC from RFMD
Simple construction, no tune, low noise, wide band, high linearity, small size...
LNA 144 MHz / SPF5189z / 90mA / NF < 0,6 db/ High IP3
S21 without 4-stage helical band pass filter (only Cavity in front)
Measure has been with 10 db attenuator.
S21 with 4-stage helical band pass filter (only Cavity in front)
IP3 Measurements - about + 12 dbm
Resume: not best NF (0,55) , not good IP3 perfomance , Hmm... but this LNA have got me better result in my noisy city. I have got from my Yagi antenna summary power about -10 dbm (FM,TV BC station near my QTH).
Lets see equal LNA-box by PE1AHX and perfomance S21 or (zip)
S21 for LNA SPF5189z
(with 5 db ATT in Output of LNA)
SWR of input for optimal NF
IP3 Measurements - about + 26 dbm
Resume: Well, if you're only going to use this LNA for Contest and EME in Out of Town area - will be All Ok !
The FM BroadCast can be rejection is better than -60 dB below 135 MHz with 4-stage helical band pass filter , BUT only in output of LNA - then all strong signal will be in front of LNA !
