Amateur radio station since 1993
RA3WDK `s Homepage
How make Flag and Preamplifier + some Life Hacks
You can download all info about this project as one file
Rotatable Flag
Bi-Directional Flag 160/80m band on Club Station RA3W
PreAmpAD8129
FLAG
FLAG
FLAG
FLAG
FLAG
Test temperature of AD8129 chip
Is importante, if you overload chip or chip is fake (beware to buy chip on Ebay from China) Temperature must be not more 45C degree
FLAG
For protection from water need to use acryl Plastik by CRAMOLIN
Cramolin plastik is a transparent acrylic resin designed to be sprayed on your electronics components, PCBs, wires and cables. The conformal coating forms a flexible protective film to protect your components from acids, salt, alkalis, alcohol, fungus and other tough conditions in the environment.
FLAG
How use Silica Gel for adsorb water and decrease humidity in box.
Attention - Silica Gel specifically designed for adsorb water and use far of food products! Silica gel packs should NOT GO NEAR FOOD. In addition, some types of silica gel designed to change color to indicate they water content (as in if they are full) contain several carcinogenic chemicals (cobaltous chloride)!
Silica Gel with humidity indicator - blue color - is OK , pink - need change adsorber. Adsorber is easy to recovery by heating to 100 С about 4-6 hours.
FLAG
FLAG
FLAG
FLAG
How make inductive choke in injector (150-200uH)?
FLAGFLAG
I use Home made instrument transformators for tune and measure preamplifier and balance filter
FLAG
Very useful thing (Core from TV CRT direction system) for making feed choke
About 12 turn of coaxial cable give 100 uH
FLAG
So much better Common-mode current chokes with EPCOS core inside
FLAG
FLAG
Old version Injector inside
PreAmpAD8129
First swith switches Flags (N/S flag or W/E flag for example), second swith switches the direction for each flag
(S or N for N/S Flag ... or E or W for W/E Flag)
PreAmpAD8129
Filters for preamplifier
  Spectr of preamp without filter Spectr of preamp with filter
0.5-10 MHz 160m filter 160m filter
0.1-20 MHz 160m filter 160m filter
Spectr evening with about -40 dbm level of SW BC band (with filter LPF 1.8 MHz)
Biggest level of SW BC station from west direction (power SW station in South Europe)
160m filter
Spectr from 0 to 10 MHz 1 hours before sunset (near Gray Line) with filter
to West
160m filter
to East
160m filter
Spectr of preamp with filter for 2 hours after sunset, west direction, max level HF BC station -45 db about 6 MHz
160m filter
Differential filters for preamplifier
160m filter
Balanced bandpass filter (BBPF) with stable bandwidth from 400 to 900 Ohm for 160 m Bi-Directional Flag and PreAmp
160m filter
Narrow Balanced bandpass filter (BBPF) with stable bandwidth from 400 to 900 Ohm for 160 m Bi-Directional Flag and PreAmp
160m nfilter
Balanced bandpass filter (BBPF) with stable bandwidth from 400 to 900 Ohm for 80&160 m Band
160m nfilter
Real frequency response of BPF 160m by transformer 1:9 in input of preamplifier
160m nfilter
BPF 160m for 800 Ohm has been simulate by Electronic Workbench
160m nfilter
LPF 160m for 800 Ohm has been simulate by Electronic Workbench
160m nfilter
LPF 80m for 800 Ohm has been simulate by Electronic Workbench
160m nfilter
Real frequency response of LPF 160/80 m and LPF 160 m Band by transformer 1:9 in input of preamplifier
160m nfilter
I recommed those LPF filter for preamplifier
160m nfilter
PreAmpAD8129
PreAmpAD8129
Before Front-End my SDR i use additional filter for 160-80m Band
PreAmpAD8129 PreAmpAD8129 PreAmpAD8129
Old Version injector for Bi-Directional Flag
160m nfilter 160m nfilter
Shield current choke for suppression current in shield of feed from my Magnetic Loop. About 30 db loss on 3,5 MHz for current on shield of feed to my Magnetic Loop. Very BroadBand Common-mode current chokes from 1 to 50 MHz
RF transformer with separate coil and only connection by magnetic field
Loss and SWR in transformer, look here for 1,8 and 3,5 MHz
Isolation between two coil by capacity with grounded shield of transformer
Isolation between two coil by capacity without grounded shield of transformer
